Date/Time: Wed, 23 Apr 2025 03:01:17 +0000
[User Discussion] - REQUEST: Moving Averages Study - "Scale Range" Option
View Count: 318
[2023-04-02 16:23:57] |
User429065 - Posts: 128 |
This is a request and/or is it even possible for a programmer to modify the "Moving Averages Study" with the option so that when applied to the main price region one of the moving averages is set to "Independent" while the other 2 moving averages are set to "Same as Region"? For example, using the MACD as the input (Sma 1/Independent Scale) would provide the optional result as shown in the attached screenshot where "Region 3" matches the MACD High/Low with the High/Low of Price while the 2 remaining MAs (20 SMa, 50 Sma/Same as Region) do not. Yes, we can do this on a lower region but this request wants to "consolidate" this result on the main price region. Ultimately, a trader can better track divergences, MA support/resistance, and crossovers directly in the main price region. Again, is this something SC can provide or is it even possible if I were to forward this request to a programmer? Is this a huge task for a programmer or something simple? Thank you very much!
Date Time Of Last Edit: 2023-04-02 16:31:42
