Date/Time: Mon, 28 Oct 2024 08:57:45 +0000
g7fx chartbook
View Count: 1424
[2023-04-01 06:55:27] |
User614300 - Posts: 1 |
hi i want to use the g7fx chartbook but when i copy it in data and then load it on software it says the chartbook is not compatible .and to contact Sierra to converting it . i attach the error pic and the file . thanks |
G7FXFOUNDATIONDOMCHARTBOOK-200330-085855.Cht - Attached On 2023-04-01 06:52:09 UTC - Size: 276.18 KB - 748 views Attachment Deleted. chartbook.PNG / V - Attached On 2023-04-01 06:53:08 UTC - Size: 5.32 KB - 257 views |
[2023-04-03 14:03:41] |
John - SC Support - Posts: 35538 |
You need to get an updated copy of the chartbook from G7FX.
[2023-04-04 01:19:36] |
Sierra_Chart Engineering - Posts: 16755 |
Can you put us in contact with who you got that Chartbook from. They need to update the Chartbooks they are providing.
[2024-10-01 10:23:42] |
_sete_ftrs - Posts: 1 |
Does the converting still working on it? ( G7FXFOUNDATIONDOMCHARTBOOK-200330-085855.Cht ) Provide this chartbook by G7FX. Very need it now for learning session. I can't go on without it, many thanks! |
[2024-10-01 14:50:16] |
You need to get an updated chartbook from G7FX.
