Date/Time: Mon, 15 Dec 2025 09:09:42 +0000
dom
View Count: 501
[2023-03-31 16:36:21]
User143551 - Posts: 104
hoe do i keep the dom in center when its running
[2023-03-31 18:33:12]
John - SC Support - Posts: 43443
If you always want to keep the last price exactly in the center of the DOM, then set the Scale Settings to the following:
- Scale Type: Constant Range
- Constant Range Scale Mode: Recenter to the Last Price On Every Update
Refer to the information here:
Chart Scale and Scale Adjusting
[2023-03-31 21:19:30]
this needs to be step buy step on charts or on dom ,way to much information ,i cannot find the study on the dom
[2023-04-03 13:50:03]
It is not a study, it is the Scale Settings. The information for how to access this is on the page we referenced. Specifically the following:
Chart Scale and Scale Adjusting: Accessing Scale Settings through the Values Scale
And then set the settings as we specified. Refer to the following:
Chart Scale and Scale Adjusting: Constant Range (Scale Range)
