Date/Time: Wed, 23 Apr 2025 03:19:24 +0000
Tools moving in Chart Region 3
View Count: 358
[2023-03-31 15:54:53]
User23815 - Posts: 210
I have studies that I mark with tools set in Chart Region 3. Most of the time when I do a Chart Replay the tools set on the chart move completely out of the viewing area. Region 2 does not do this. How do I fix this? Thanks
[2023-03-31 18:19:04]
John - SC Support - Posts: 39428
The first possibility is simply that the data is different enough at the position of the replay that the drawings are not showing.
But also take a look at the following:
Lines/Rays or Other Chart Drawings Move After Drawing Them
[2023-04-01 09:39:57]
Sierra_Chart Engineering - Posts: 19307
It must be the value of the study displayed in that region which is changing.
[2023-04-01 19:28:57]
Just FYI the two tools I add to the region are the Horizontal Ray and the Ellipse. Thanks for the help.
