Date/Time: Thu, 10 Sep 2026 09:20:00 +0000
Connecting combine to already existing account.
View Count: 722
[2023-03-31 15:37:38]
Darksound - Posts: 56
Just started earn2trade combine. They only offer Rithmic data. Right now I have Denali data with CQG order routing.
1. Can I use my existing Denali data and just use Rithmic for order routing, while still maintaining my live account with CQG order routing? If so, how should I connect?
2. Can I do so in a second instance of the same installation?
3. Or should I connect through another installation of SC?
Thank you.
[2023-03-31 17:54:55]
John - SC Support - Posts: 47822
Yes, you can do this, and it is how we recommend doing it. The easiest way to do this is to install a second Sierra Chart on the same computer and have that second installation connect to your earn2trade account. Refer to the following for how to install a second Sierra Chart:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
Not when using the "File >> New Instance" option. See our response to #1 above.
Yes.
[2023-04-01 09:37:39]
Sierra_Chart Engineering - Posts: 24821
Yes you can do this . Refer to the documentation here:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
Date Time Of Last Edit: 2023-04-01 09:37:46
