Date/Time: Wed, 23 Apr 2025 03:19:24 +0000
Two combined windows
View Count: 344
[2023-03-31 15:24:12]
User904434 - Posts: 63
I have 2 opened windows in 1 Chartbook. In one window I have a chart with the price on the right and in the other window I have a chart with the price on the left. I would like to combine these two windows with a price so that they only move up and down, but it is pinned to the same price.
imagewindows to combine.JPG / V - Attached On 2023-03-31 15:19:54 UTC - Size: 165.97 KB - 98 views
[2023-03-31 17:52:20]
John - SC Support - Posts: 39428
You can try linking the scale between those two charts. Refer to:
Chart Settings: Linking
Just be aware that a Trading DOM has to use a Constant Range scale type, so you will probably need to change your Chart to be the same setting.
