Date/Time: Wed, 23 Apr 2025 03:04:27 +0000
Trading DOM - Header
View Count: 495
[2023-03-31 11:14:25]
User551647 - Posts: 25
Dear Sierra Chart team,
I am using a separate instance of Sierra Chart for price ladders/ Trading DOM only. To observe them at the same time I have them arranged side-by-side as you can see in the screenshot. I am generally very happy with it.
The only thing I am always fiddling around with is the width of the window because of the header line. As you can see, I am using DPL, Qty and PQ. (Sometimes others).
In general, the header is a slim and convenient replacement for the much bigger Trading Window.
The Trading DOM header is limited to the left most area where the Studies would go to.
I am currently using none of the studies and would prefer to have the header in a separate line above the entire DOM.
I believe there is no setting for this. Are you considering or can you consider changes to this system to have the entire header accessible in a separate line above to have it completely visible even for small trading DOMs?
Thank you very much!
https://www.sierrachart.com/image.php?Image=1680260683832.png
[2023-03-31 17:30:50]
John - SC Support - Posts: 39428
This is not something that has come up before, so this is a very low priority, although we can not say when we would ever get to any particular feature. But we have taken this as a Feature Request.
