Date/Time: Wed, 23 Apr 2025 03:04:37 +0000
Latest upgrade screwed up account connection, teton account not assigned
View Count: 552
[2023-03-30 19:33:08]
User984500 - Posts: 7
I have tried to follow the directions in the documentation several times. I called Advantage/Stage 5 and they don't seem to know what I'm talking about. This shouldn't be so damn hard.
[2023-03-30 21:07:55]
John - SC Support - Posts: 39428
We are not fully understanding.
If you have an account with Advantage/Stage 5 and you are setup to use the Teton Order Routing Service, then go through the Setup Instructions at the following link starting at step #7:
Sierra Chart Teton Futures Order Routing: Setup Instructions
If it is something else, then let us know what you need.
[2023-03-31 12:20:54]
What does set up to use the Teton Order Routing Service mean? I was already using SC with my account Advantage/Stage 5. What else do I have to do? I believe my clearing firm is Dorman actually, but I've tried both and neither works.
[2023-03-31 13:33:39]
Sierra_Chart Engineering - Posts: 19307
Connect to the data feed:
Select "File >> Disconnect"
Select "File >> Connect to Data Feed"
[2023-03-31 14:11:51]
Reading Internal Order ID file. | 2023-03-31 07:11:53.120
Reading Trade Orders file. | 2023-03-31 07:11:53.310
Reading Trade Positions file. | 2023-03-31 07:11:53.317
Reading Trade Account Data files. | 2023-03-31 07:11:53.321
UDPListener (1540). Port 22904 | Listening on UDP port 22904. | 2023-03-31 07:11:53.334
Software version: 2488 64-bit | 2023-03-31 07:11:53.334
Primary Thread ID: 30532 | 2023-03-31 07:11:53.334
Usage end date: 2023-04-14 | 2023-03-31 07:11:53.334
Enabled for: Advanced Features 2. | 2023-03-31 07:11:53.334
Enabled for: Sierra Chart Historical Data Service. | 2023-03-31 07:11:53.334
Enabled for: Denali Real-Time Exchange Data Feed. | 2023-03-31 07:11:53.334
Enabled for: Delayed Denali Exchange Data Feed. | 2023-03-31 07:11:53.334
Enabled for exchange2: CME | 2023-03-31 07:11:53.334
Enabled for exchange2: fairx_exchange.data | 2023-03-31 07:11:53.334
Allow Support for Sierra Chart Data Feeds is enabled. | 2023-03-31 07:11:53.334
Current selected Data/Trading service: SC Data - All Services | 2023-03-31 07:11:53.334
Custom symbol settings values: enabled | 2023-03-31 07:11:53.334
Chart Update Interval: 500 | 2023-03-31 07:11:53.334
Intraday Data Storage Time Unit: 1 | 2023-03-31 07:11:53.334
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2023-03-31 07:11:53.334
2023-03-31 12:11:53 Local computer time in UTC | 2023-03-31 07:11:53.334
2023-03-31 07:11:53 Local computer time in SC Time Zone | 2023-03-31 07:11:53.334
2023-03-31 12:11:49 Server time in UTC | 2023-03-31 07:11:53.334
Local computer UTC time and Server UTC time difference: 1 seconds. | 2023-03-31 07:11:53.334
Program path: C:\SierraChart\ | 2023-03-31 07:11:53.334
Data Files path: C:\SierraChart\Data\ | 2023-03-31 07:11:53.334
OS Version Number: 10.0 | 2023-03-31 07:11:53.334
Locale Setting: C | 2023-03-31 07:11:53.334
DLLs: UserContributedStudies_64.dll | 2023-03-31 07:11:53.334
Allowed protected custom studies: | 2023-03-31 07:11:53.334
Crash reporter started: true | 2023-03-31 07:11:53.334
Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2023-03-31 07:11:53.364
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2023-03-31 07:11:53.422
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-03-31 07:11:53.552
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2023-03-31 07:11:53.552
Received 5 login tokens. | 2023-03-31 07:11:53.801
Symbol settings MD5 received. Request ID: 1. | 2023-03-31 07:11:55.458
Requested symbol settings for service code scdataallservices. Request ID: 2. | 2023-03-31 07:11:55.458
Symbol settings received. Request ID: 2. | 2023-03-31 07:11:58.288
SC Data - All Services | Connected to server complete. | 2023-03-31 07:12:00.032
Triggering next historical data download in queue. | 2023-03-31 07:12:00.032
No download requests in the queue to start downloads for. | 2023-03-31 07:12:00.033
No download requests in the queue to start downloads for. | 2023-03-31 07:12:00.035
No download requests in the queue to start downloads for. | 2023-03-31 07:12:00.036
MESM23_FUT_CME #10 | Reloading chart. | 2023-03-31 07:12:19.106
MESM23_FUT_CME 1 Min #1 | Reloading chart. | 2023-03-31 07:12:19.133
ESZ22_FUT_CME #5 | Reloading chart. | 2023-03-31 07:12:19.561
ESZ22_FUT_CME #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-03-31 07:12:19.562
/ESZ22 #2 | Reloading chart. | 2023-03-31 07:12:19.599
ESZ22_FUT_CME #4 | Reloading chart. | 2023-03-31 07:12:19.651
ESZ22_FUT_CME #7 | Reloading chart. | 2023-03-31 07:12:20.101
ESZ22_FUT_CME #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-03-31 07:12:20.101
MESM23_FUT_CME #11 | Reloading chart. | 2023-03-31 07:12:20.621
MESM23_FUT_CME #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-03-31 07:12:20.622
MESM23_FUT_CME #3 | Reloading chart. | 2023-03-31 07:12:20.677
MESM23_FUT_CME #6 | Reloading chart. | 2023-03-31 07:12:20.780
MESM23_FUT_CME #10 | StartDateTimeForLoadingOrderFills: 2023-03-01 08:30:00 | 2023-03-31 07:12:20.830
/ESZ22 #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\[ESZ22.scid | 2023-03-31 07:12:20.974
MESM23_FUT_CME #3 | StartDateTimeForLoadingOrderFills: 2023-02-28 17:01:00 | 2023-03-31 07:12:21.136
MESM23_FUT_CME #6 | StartDateTimeForLoadingOrderFills: 2023-02-28 17:01:00 | 2023-03-31 07:12:21.193
Using symbol data fast lookup vector | 2023-03-31 07:12:21.335
SC Data - All Services | Starting real-time market data updates for: MESM23_FUT_CME. ID: 1 | 2023-03-31 07:12:21.335
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: MESM23_FUT_CME | 2023-03-31 07:12:21.335
SC Data - All Services | Requesting security definition data for: MESM23_FUT_CME. ID: 1 | 2023-03-31 07:12:21.335
No historical data client is currently set to download historical Intraday data for MESM23_FUT_CME. | 2023-03-31 07:12:21.335
Real-time Intraday chart data file updates started for MESM23_FUT_CME | 2023-03-31 07:12:21.335
Opened cached Intraday file: C:\SierraChart\Data\MESM23_FUT_CME.scid. Thread ID: 30532 | 2023-03-31 07:12:21.335
Intraday chart data file opened for MESM23_FUT_CME | 2023-03-31 07:12:21.335
SC Data - All Services | Starting real-time market data updates for: ESZ22_FUT_CME. ID: 2 | 2023-03-31 07:12:21.377
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: ESZ22_FUT_CME | 2023-03-31 07:12:21.377
SC Data - All Services | Requesting security definition data for: ESZ22_FUT_CME. ID: 2 | 2023-03-31 07:12:21.378
Requesting market depth updates for: ESZ22_FUT_CME if supported. | 2023-03-31 07:12:21.378
Separate subscription for market depth updates not supported. ESZ22_FUT_CME | 2023-03-31 07:12:21.378
Requesting market depth updates for: MESM23_FUT_CME if supported. | 2023-03-31 07:12:21.378
Separate subscription for market depth updates not supported. MESM23_FUT_CME | 2023-03-31 07:12:21.378
No historical data client is currently set to download historical Intraday data for ESZ22_FUT_CME. | 2023-03-31 07:12:21.378
Real-time Intraday chart data file updates started for ESZ22_FUT_CME | 2023-03-31 07:12:21.378
Opened cached Intraday file: C:\SierraChart\Data\ESZ22_FUT_CME.scid. Thread ID: 30532 | 2023-03-31 07:12:21.378
Intraday chart data file opened for ESZ22_FUT_CME | 2023-03-31 07:12:21.379
SC Data - All Services | Starting real-time market data updates for: /ESZ22. ID: 3 | 2023-03-31 07:12:21.380
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: /ESZ22 | 2023-03-31 07:12:21.380
SC Data - All Services | Requesting security definition data for: /ESZ22. ID: 3 | 2023-03-31 07:12:21.380
No historical data client is currently set to download historical Intraday data for /ESZ22. | 2023-03-31 07:12:21.380
Real-time Intraday chart data file updates started for /ESZ22 | 2023-03-31 07:12:21.380
Opened cached Intraday file: C:\SierraChart\Data\[ESZ22.scid. Thread ID: 30532 | 2023-03-31 07:12:21.381
Intraday chart data file opened for /ESZ22 | 2023-03-31 07:12:21.381
SC Data - All Services | Disconnected. | 2023-03-31 07:13:10.421
Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 3. | 2023-03-31 07:13:10.576
Current selected Data/Trading service: Teton CME Order Routing | 2023-03-31 07:13:10.576
Symbol settings MD5 received. Request ID: 3. | 2023-03-31 07:13:12.650
Requested symbol settings for service code sc_futures_direct.dtc.trading. Request ID: 4. | 2023-03-31 07:13:12.650
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-03-31 07:13:14.934
Symbol settings received. Request ID: 4. | 2023-03-31 07:13:15.007
Teton CME Order Routing | Firm: Dorman | 2023-03-31 07:13:16.926
Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-03-31 07:13:16.926
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-03-31 07:13:16.997
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-03-31 07:13:16.997
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2023-03-31 07:13:16.997
Teton CME Order Routing | Network connection to server complete. | 2023-03-31 07:13:17.033
Teton CME Order Routing | Starting socket receive thread. | 2023-03-31 07:13:17.033
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-03-31 07:13:17.033
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-03-31 07:13:17.133
Teton CME Order Routing | Sending logon request message. | 2023-03-31 07:13:17.133
Teton CME Order Routing | Received logon response. | 2023-03-31 07:13:17.639
Teton CME Order Routing | Server Name: SC DTC Server. | 2023-03-31 07:13:17.639
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-03-31 07:13:17.639
Teton CME Order Routing | Connection error: No trade accounts assigned | 2023-03-31 07:13:17.639 *
Teton CME Order Routing | Waiting for socket receive thread to end | 2023-03-31 07:13:17.710
DTC Client socket (1) | CloseSocket call. | 2023-03-31 07:13:17.710
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-03-31 07:13:17.711
Teton CME Order Routing | Disconnected. | 2023-03-31 07:13:17.711
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-03-31 07:13:17.747
DTC Client socket (1) | Closed. | 2023-03-31 07:13:17.747
(Removed)
Date Time Of Last Edit: 2023-03-31 15:05:02
[2023-03-31 15:04:42]
Who is your broker? Who is the introducing broker?
[2023-03-31 15:10:33]
Advantage or Advantage/S5 - both are on your pulldown menu. Clearing broker is Dorman
[2023-03-31 16:31:39]
So is your account with Stage 5? Or is it direct with Dorman.
Date Time Of Last Edit: 2023-03-31 16:31:57
[2023-03-31 17:29:47]
The introducing broker is Advantage.
[2023-04-03 13:55:57]
Do you have an update on this issue? As much as I like this product (and I do), if I can't trade it is pretty much useless to me.
[2023-04-03 14:16:28]
We will have someone follow up with you regarding this.
[2023-04-03 15:07:39]
SC Support - Posts: 1956
Spoke to User984500, we have reached out to Stage5 (Advantage Clearing) for help with this.
[2023-04-03 15:56:50]
Spoke to User984500, informed that issue is resolved
[2023-04-03 15:58:45]
It's looking good so far; I appreciate very much your help in resolving this issue.
Terry Sykora
