Date/Time: Wed, 23 Apr 2025 03:16:03 +0000
Temporarily
View Count: 347
[2023-03-30 16:22:26]
User535772 - Posts: 1
Good morning.
Is there a way to temporarily "freeze" the DOM price ladder so I can place a limit order during a fast-moving market?
I know there's a setting the permanently freezes the DOM, but then fast-moving prices disappear from the visible range.
The SC DOM is the only platform I've ever used that does not seem to have this critical feature.
Thank you!
[2023-03-30 20:51:39]
John - SC Support - Posts: 39428
If you right-click on the Scale on the right and select Scale Range: User Defined with Auto-Set then the scale will stay locked at the prices that are showing at that time. Refer to the following:
Chart Scale and Scale Adjusting: Using Fixed Values for Top and Bottom of Scale Range
You can also setup a Control Bar button and/or Keyboard Shortcut to activate this mode.
