Date/Time: Wed, 23 Apr 2025 03:04:39 +0000
Import/Export general settings and general graphic settings
View Count: 515
[2023-03-30 15:01:30]
User146848 - Posts: 124
I need to restore general settings because an instance was not able to get closed correctly due to a lack of free space on my hdd. Instead of adjusting each and every single setting i want to import the whole setup file. But i couldnt find the infos. So pls give me advice for doing so.
Thx
[2023-03-30 15:16:08]
Sierra_Chart Engineering - Posts: 19307
The file that contains this information is Sierra4.config. Make sure you copy and replace that file only when Sierra Chart is not running.
Date Time Of Last Edit: 2023-03-30 15:16:21
[2023-03-30 19:13:53]
Is there also such an easy way for transfering general graphic settings between instances?
[2023-03-30 21:05:22]
John - SC Support - Posts: 39428
The only way to do this is to copy that file (Sierra4.config) to the other instance.
