Date/Time: Wed, 23 Apr 2025 03:01:15 +0000
One click
View Count: 345
[2023-03-30 14:19:55] |
User344478 - Posts: 161 |
Is it possible disable SC trade simulation mode and get chart trade mode on in one click and return with one click? |
[2023-03-30 15:53:24] |
John - SC Support - Posts: 39428 |
There is not a way to do this directly. But since both options can be setup to have Keyboard shortcuts, you might be able to create some kind of keyboard macro using a 3rd party software that could do it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
