Date/Time: Wed, 23 Apr 2025 03:01:16 +0000
NUMBER BARS STUDY TICK INCREMENTS
View Count: 809
[2023-03-30 14:04:08]
User346587 - Posts: 19
Hi, I have 2 charts here of the 10y bond futures.
one is in 2 ticks increments (the black one) and the other one is in 1 tick increments (the lighter one).
The symbol settings are the exact same and I don't find a way to put the black one into 1 tick increments.
If it's in the study settings then I don't find it.
imageScreenshot_156.png / V - Attached On 2023-03-30 14:01:59 UTC - Size: 22.96 KB - 141 views
imageScreenshot_157.png / V - Attached On 2023-03-30 14:02:04 UTC - Size: 15.85 KB - 122 views
[2023-03-30 15:14:03]
Sierra_Chart Engineering - Posts: 19307
What is the Tick Size in Chart >> Chart Settings >> Symbol set to for each of these charts?
[2023-03-30 15:18:36]
Tick Size for both charts seem to be the same: 0.5/32
see screenshots
imageScreenshot_159.png / V - Attached On 2023-03-30 15:18:19 UTC - Size: 35.44 KB - 107 views
imageScreenshot_160.png / V - Attached On 2023-03-30 15:18:25 UTC - Size: 37.13 KB - 113 views
[2023-03-30 16:00:50]
John - SC Support - Posts: 39428
Check the Chart >> Chart Settings >> Chart Data >> Volume at Price Multiplier for Intraday Chart. It sounds like this is set to a value of 2, if it is, then change it to 1.
If that is not it, then are both of these charts in the same installation of Sierra Chart, or do you have more than 1 installation?
[2023-03-30 20:29:28]
Hi, yes the issue was with Volume at Price Multiplier for Intraday Chart.
I changed it to 1 and now it shows every single tick on the numbers bars study.
Thank you!!
