Date/Time: Wed, 23 Apr 2025 03:04:39 +0000
How to set an alert based on Boolean type indicator?
View Count: 420
[2023-03-30 08:49:41]
BenjFlame - Posts: 337
let's take for exemple, the "Halftrend" indicator, which displays up or down arrow based on its specific calculation.
How to set an audio alert for when current bar has an up arrow for exemple, but do nothing on bars with no arrows ?
If possible, from study and not from ACSIL.
[2023-03-30 09:06:02]
User907968 - Posts: 840
If you want separate alert sounds for up and down, use Color Bar Based on Alert Condition - Color Bar Based on Alert Condition
If not then set alert condition in study itself.
In either case all you are testing for is non-zero on the arrow subgraph.
Using HalfTrend example, setting up arrow alert within study: SG2<>0
Using HalfTrend example and alert in CBBoAC: =ID??.SG2<>0
[2023-03-30 09:12:55]
Ah, testing for non zero, ok got it thanks.
