Date/Time: Thu, 28 Nov 2024 17:55:14 +0000
[Programming Help] - Engulfing Renko Bar Code
View Count: 395
[2023-03-29 20:17:14]
User727901 - Posts: 5
Does anyone have access to an engulfing renko bar code? I assume this would be a simple and quick resolution but could be wrong. Support - if this is not something you are able to assist with can you
please point me in the write programmer's direction? Thank you!
[2023-04-02 23:20:27]
jeden8l - Posts: 47
Engulfing renko bar is a trading strategy, not custom Renko bar itself as far I understand.
Difficult, inexpensive way: learn alerting system (Color Bar Based on Alert Condition), lease SST AT V2 from Frederik (simplesystemtrading.com) and code it yourself.
Very difficult (if you never coded), free: code an ACSIL strat yourself
Quite expensive, easiest way: find a coder. Most of them charge around $100 per hour. https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
[2023-04-03 13:12:10]
Sawtooth - Posts: 4120
Use the Outside Bar study.
[2023-04-11 15:51:47]
Thank you. The outside bar study did not solve the problem but did get me a step closer. Thanks for the response!
