Date/Time: Mon, 15 Dec 2025 09:09:45 +0000
Sending orders problem
View Count: 412
| [2023-03-29 17:09:59] |
| WeroTrader - Posts: 46 |
Is there a problem sending orders to Bitmex through an automatic trading study? I'm sure I have all the parameters in the correct order: 1. Trade Simulation Mode On = without check mark 2. Auto Trading Enabled - Global = check mark is present 3. Auto Trading Enabled - Chart = check mark is present 4. In my already compiled code sc.SendOrdersToTradeService = true; 5. Connected to Bitmex Trading Direct data through my API key and API secret. Still I get the message: XRPUSD-BMEX[M] Aligned Renko 3t #1 | SendOrdersToTradeService is not consistent with 'Trade >> Trade Simulation Mode On' setting. Order action ignored. | 2023-03-28 23:34:19.620 Is there a problem or am I missing some step or setting? I thank you for an answer |
| [2023-03-30 14:12:20] |
| Sierra_Chart Engineering - Posts: 21843 |
This means the settings are not as you say: Still I get the message: XRPUSD-BMEX[M] Aligned Renko 3t #1 | SendOrdersToTradeService is not consistent with 'Trade >> Trade Simulation Mode On' setting. Order action ignored. | 2023-03-28 23:34:19.620 Refer to: Automated Trading Management: SendOrdersToTradeService Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
