Date/Time: Tue, 22 Apr 2025 22:22:33 +0000
Copying Drawings from one Chartbook to another
View Count: 321
[2023-03-29 16:45:59] |
User643426 - Posts: 136 |
How do I copy Drawing from one Chartbook to another Chartbook?
[2023-03-29 18:50:10] |
John - SC Support - Posts: 39428 |
Refer to the instructions at the following (specifically the 4th paragraph down): Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
