Date/Time: Tue, 22 Apr 2025 22:54:00 +0000
Cannot Compile Code
View Count: 324
[2023-03-29 13:29:11] |
User717744 - Posts: 4 |
Hi, I've already finished my code and tried to compile it. After clicking on build, nothing happened. No error occurred or DLL created. No matter I choose remote or locally. I already installed the compiler. Could you help me to solve this problem? Thank you |
[2023-03-29 14:01:20] |
Sierra_Chart Engineering - Posts: 19305 |
Do a Remote Build again and wait about 30 to 60 seconds .
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-29 14:01:32
[2023-03-29 15:36:38] |
Hi, I just tried but still nothing happened. |
