Date/Time: Tue, 22 Apr 2025 22:40:28 +0000
Correct package
View Count: 379
[2023-03-29 11:13:50] |
AMINE BERRECHACH - Posts: 26 |
Hi What package i should use if i want to use the advanced studies (tpo ,number bars…) and connect to denali exchange feed Is package 5 enough? |
[2023-03-29 17:09:54] |
SC Support - Posts: 1956 |
Hi Amine, to get access to the Denali Data Feeds and also have access to the advanced features that you have named "tpo ,number bars", you would need to be on SP11 (or SP12): Description of Service Packages and Pricing: Packages You can convert your SP5 Usage Time into SP11 Usage Time by activating an SP11 option from this drop-down here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#ServicePackage (the conversion ratio is the relevant price ratio) What data do you need, what asset class are you focused on? |
[2023-03-29 17:15:15] |
I want to use in a couple of months denali data feed with teton order routing And the asset class i am interested in is the stock market index futures specifically the es futures |
[2023-03-29 17:27:18] |
Hi Amine, do you have a Futures Trading Account now? The CME Group expects you to have a Futures Trading Account in order to qualify as a Non-Professional [*Note: we know of only the CME Group having this rule, not EUREX, not CFE, not NASDAQ, not NYSE, just the CME Group*] From the CME Group Certification: "The Non-Professional Subscriber must: a. have an active and funded futures trading account; b. be an individual, natural person or small business entity" The solution if you do not have a Futures Trading Account (but would otherwise qualify as a Non-Professional) is described here: Easy Solution to CME Funded Trading Account Requirement |
[2023-03-29 17:31:31] |
Thank you i know this ,i will open a futures account with iron beam in a couple of months
[2023-03-29 17:42:03] |
Good stuff, in that case, until then you can use the Delayed Streaming Futures Feed which comes without an extra Data Exchange Fee. Delayed Exchange Data Feed |
