Date/Time: Thu, 28 Nov 2024 20:53:31 +0000
Making grid lines more Transparent
View Count: 349
[2023-03-29 09:59:09]
User820791 - Posts: 15
Is there a way I can change horizontal lines transparency without changing it's color?
Thank you.
[2023-03-29 18:27:13]
John - SC Support - Posts: 36350
We do not have a Transparent option for the Horizontal Grid. The only option would be to change line size (or if you are not using OpenGL, you should be able to change the Line Style as well). Refer to the following:
Graphics Settings: Chart Grid
