Date/Time: Tue, 22 Apr 2025 22:30:34 +0000
Footprint charts are blank
View Count: 458
[2023-03-29 03:32:51]
User968091 - Posts: 47
My Sierra Footprint charts wont load upon opening Sierra and I am getting the message across products "caught in an unhandled exception."
image2023-03-28_20-30-05.png / V - Attached On 2023-03-29 03:30:48 UTC - Size: 120.41 KB - 103 views
[2023-03-29 08:36:19]
Sierra_Chart Engineering - Posts: 19305
Disable the use of OpenGL if you are using that:
Graphics Settings: Use OpenGL for Chart Graphics (Global Settings >> Graphics Settings >> Other)
And restart Sierra Chart.
Also run Sierra Chart in safe mode:
Sierra Chart - Software Login Instructions: Using Safe Mode
This should not matter but also update Sierra Chart to the latest version:
But there are no known issues that would cause this, for years now.
Date Time Of Last Edit: 2023-03-29 08:37:02
