Date/Time: Wed, 23 Apr 2025 03:04:40 +0000
Version information and data
View Count: 810
[2023-03-29 03:23:56]
User240686 - Posts: 86
I used Sierra a few years back when Rithmic was supported. You stopped supporting it and now you support it again. I trade through Bulenox and sometimes other evaluation companies using the Rithmic feed. I have some chartbooks that I would still like to use but you have updated far ahead now and my chartbooks will not work.
1. How can i import my old chartbooks?
2. I use TPO so what version will i need to access advanced charts and rithmic data feed?
3. If I also subscribe to the denali datafeed what will that provide me if I have to place my orders through Rithmic?
5. If I subscribe to a trial version will i be able to test all the above?
Thank You for your support
[2023-03-29 08:31:17]
Sierra_Chart Engineering - Posts: 19307
1. Refer to:
Chartbooks (Workspaces): Opening Older Chartbooks
2. You will need Service Package 11:
Description of Service Packages and Pricing
3. It will provide reliable market data which will not give you any problems. Refer to:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
4. Yes we will activate this now for you.
Date Time Of Last Edit: 2023-03-29 08:31:31
[2023-03-29 09:07:06]
Will package 11 allow me access to denali as well as use rithmic?
Thank you
[2023-03-29 09:31:36]
Yes.
[2023-03-29 09:35:58]
i have downloaded 2363 version and cannot open my charts from some time back and i dont seem to be able to find version 2240. Can you send it to me please?
[2023-03-29 16:52:55]
Follow the instructions here to access that version:
Software Download: Full Control Rollback Procedure
[2023-03-30 10:24:08]
i am now on the latest version after opening up my charts. I am now trying to connect to rithmic data feed for my evaluation accounnts. I select Rithmic Trading but the server list is blank.
How can i test out the feed?
[2023-03-30 10:47:50]
Follow the instructions here regarding this:
Rithmic Trading Platform Service: Setup Instructions
In particular step 9.
Date Time Of Last Edit: 2023-03-30 10:47:58
[2023-03-30 11:24:42]
yes i know how to do it. The issue is when i select rithmic there is no server list. I am on a trial so...
[2023-03-30 11:43:25]
Did you do as it said in step 9, 10, 11? Your account is not on a trial any longer.
Date Time Of Last Edit: 2023-03-30 11:43:52
[2023-03-30 11:47:57]
i asked for it to be on a trial to test it all out
[2023-03-30 13:25:21]
A trial does not support a connection to Rithmic. So your account is on Service Package 11 which does support a connection to Rithmic.
[2023-03-30 14:08:44]
ok. well i cant connect to rithmic and its what i wanted to test. I also have not paid so as far as i am aware i am on a trial and not able to trial it
[2023-03-30 14:17:42]
If you followed the instructions, the problem is the Rithmic server is not delivering the server list or you have a connectivity problem.
We recommend trying again later.
[2023-03-31 07:37:56]
all i have is SC Data. No drop down of servers for any other service. Its just blank
[2023-03-31 09:20:20]
That is not true:
Please move on elsewhere. We have no control over this. Either the instructions are not being followed or you have a connectivity problem.
Date Time Of Last Edit: 2023-03-31 09:20:43
[2023-03-31 09:26:30]
it did come good in the end. The service i would need is $36 is that correct? Would that give me Denali data as well as rithmic
[2023-03-31 11:34:25]
Yes if you use Service Package 10. That will give you the Denali data feed and access to Rithmic. There are also exchange fees that have to be paid. More information about that:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges (Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges)
Very important to read the above link.
Date Time Of Last Edit: 2023-03-31 11:34:43
