Date/Time: Thu, 28 Nov 2024 21:37:21 +0000
not connecting to sierra server
View Count: 428
[2023-03-29 02:21:01] |
User576595 - Posts: 14 |
i cant get HSI data this morning pls advise thanks ed |
Private File |
[2023-03-29 02:49:45] |
user - Posts: 78 |
same here, isn't the datafeed discontinue at the end of April?
[2023-03-29 05:06:34] |
another question : is it possible to place trade using sierra chart trade mode to interactive brokers without the soon-to-be discontinued HKFE data feed ?
[2023-03-29 05:32:41] |
Sierra_Chart Engineering - Posts: 17206 |
This is now resolved. is it possible to place trade using sierra chart trade mode to interactive brokers without the soon-to-be discontinued HKFE data feed Yes.
[2023-03-29 21:51:21] |
a, are there any steps we need to follow after discontinuance if keeping to use sierra chart trade mode on interactive brokers ? b, do u guys suggest any alternative reliable source for HKFE data ? thank you |
[2023-03-30 04:13:19] |
No nothing you need to do. We have no recommendation for a source of reliable HKFE data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
