Date/Time: Tue, 22 Apr 2025 22:40:30 +0000
"use of chart graphics settings for subgraph" function
View Count: 352
[2023-03-28 23:45:48] |
User722905 - Posts: 9 |
Currently the "use of chart graphics settings for subgraph" function is permitted on the "Study Subgraphs Divide/Ratio" study, but not other simular studies like "Study Subgraphs Divide/Ratio", "Study "Study Subgraphs Average" etc. Please modify the other Study Subgraphs Studies so that the output can be displayed as bar charts, candle sticks etc. Thank you for your consideration, David 3-28-23 |
[2023-03-29 17:38:01] |
John - SC Support - Posts: 39428 |
In order for data to be displayed as a Bar/Candle, it needs to have 4 values - an Open, High, Low, and Close. Most other studies do not generate this information. If you have something you want to use for these four items, then use the Spreadsheet Formula (Bar) study to create the bars/candles. This study has 4 inputs for each of the items that make up a bar. We do not have separate documentation for this, but the documentation for the Spreadsheet Formula all applies. You will find this here: Spreadsheet Formula For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
