Date/Time: Tue, 22 Apr 2025 22:33:04 +0000
My Sierra Chart Layout is not coming up on a Screen
View Count: 310
[2023-03-28 21:37:39] |
User838124 - Posts: 1 |
Hi team I downloaded the layout given to me by my mentor but my Layout in Sierra charts does not look the same. Please see the attached screenshots of how my layout should look like and how it actually looks. Are you able to assist? Thanks
[2023-03-28 21:38:00] |
Sierra_Chart Engineering - Posts: 19305 |
First thing to do is to translate the symbols to the current service using this Edit menu command: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
