Date/Time: Tue, 22 Apr 2025 22:48:37 +0000
Volumes in footprint
View Count: 856
[2023-03-28 18:55:31] |
User303272 - Posts: 4 |
Greetings, in the attached footprint chart the deltas (Ask Vol - Bid Vol) are shown: https://www.sierrachart.com/image.php?Image=1680029183729.png Although the volume within the candle at the price with the green arrow (347) is twice as large as the volume in the candle with the yellow arrow (165), the plot is such that it appears that both volumes are equal. Is there a way to correctly display the proportionality of the different volumes? Thank you very much. |
[2023-03-28 20:18:51] |
John - SC Support - Posts: 39428 |
Refer to the following Input for the Numbers Bars: Numbers Bars: Volume Profile Bars Length Relative to All Visible Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
