Date/Time: Tue, 22 Apr 2025 22:27:55 +0000
Equities data clarification
View Count: 422
[2023-03-27 16:09:40] |
User558455 - Posts: 70 |
I am trying to renew my equities data which expired. Not that I have seen Sierra is cancelling this service can you explain the the best method to get the equites data that come from NYSE? thanks |
[2023-03-27 17:15:01] |
John - SC Support - Posts: 39428 |
You will have to get them through the NASDAQ TotalView exchange on our Denali Exchange Data Feed. You already have the exchange active for your account. Refer to the notes for this exchange at the following link: Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes Note that we have deactivated the Sierra Chart connection so you are no longer paying the $25.00 for that. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-27 17:55:31] |
Can I still bring in data from DTN?
[2023-03-27 21:28:38] |
Yes, you can still get data from DTN by following the instructions here: DTN IQ Feed Data Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-28 08:04:48] |
Sierra_Chart Engineering - Posts: 19305 |
Also refer to this thread: Discontinuing of Old Sierra Chart/Barchart Exchange Data Feed | Replacement Data Feeds! Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
