Date/Time: Tue, 22 Apr 2025 23:14:04 +0000
extends calculated values for several periods into the future
View Count: 346
[2023-03-26 05:12:00]
User99728 - Posts: 8
Is it possible to write a custom indicator in SierraCharts that extends its calculated values for several periods into the future?
[2023-03-27 15:02:01]
John - SC Support - Posts: 39428
Depending on what you are doing and how you want to do it - you would either take the value of the subgraph you want to extend and copy that data point to all subsequent indices.
Or, you could use the sc.AddLineUntilFutureIntersection() function. Refer to the following:
ACSIL Interface Members - Functions: sc.AddLineUntilFutureIntersection()
Or you could use a Draw Style of Line from Last Bar to Edge:
Chart Studies: Line at Last Bar to Edge (ACSIL: DRAWSTYLE_LINE_AT_LAST_BAR_TO_EDGE)
