Date/Time: Tue, 22 Apr 2025 22:51:23 +0000
Studies in Region 1 of Numbers Bar
View Count: 397
[2023-03-25 19:45:19] |
Ed Levy - Posts: 18 |
Hello, I want to insert the Total Vol of individual numbers bar above each individual numbers bar and Vol Bar Diff below each individual numbers bar in the same Chart Region (Region 1). I also would like to express AskV - BidV as a vertical bar in Chart Region 2. I cannot seem to make this happen. I've already created these subgraphs in Numbers Bars Calculated Values. Thank you.
[2023-03-27 06:11:55] |
Ackin - Posts: 1865 |
look here: Delta and number of contracts above footprint |
[2023-03-29 11:47:46] |
Hello, I'm still having trouble getting a study, Vol Bar Diff, below the numbers bars. I can bring it up in region 2 but not under the bar itself. I've included the - Volume at Price Threshold Alert V2 study and based it on numbers bars calculated values but still cannot get it to display. I've attached screenshots. Can you please tell me what I'm missing? Thanks. |
[2023-03-29 18:33:31] |
John - SC Support - Posts: 39428 |
We are confused - are you trying to get the Volume Bar Difference or the Volume at Price Threshold Alert V2 to show, and how? For the Volume Bar Difference, we assume you have that value available somewhere (like from the Numbers Bars Calculated Values study). You would then use the Study Subgraph Above/Below Bar as Text to actually display the information above or below the bar. Refer to the following: Study Subgraph Above/Below Bar as Text For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
