Date/Time: Tue, 26 Nov 2024 20:32:31 +0000
Vertical Lines
View Count: 979
[2014-06-18 16:57:39] |
TGuth1 - Posts: 6 |
Is there a way to have vertical lines every hour on the chart starting with the time that the pit contract opens. For example currencies - 7:20 open and ES - 9:30 open. So every hour from those times? |
[2014-06-18 17:00:12] |
Yes. This can be done with the Vertical Grid: http://www.sierrachart.com/index.php?l=doc/doc_ChartMenu.html#Vgrid Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
