Date/Time: Wed, 23 Apr 2025 03:19:23 +0000
formula
View Count: 341
[2023-03-25 18:58:16] |
User411320 - Posts: 319 |
Hello, How would I go about utilizing a formula to calculate on every bar? v1-v2/[(v1+v2)/2]x100, this is the formula with v1 and v2 being ask vol and bid vol. |
[2023-03-25 21:49:33] |
Sawtooth - Posts: 4209 |
If you are using Alert syntax: =AV-BV/((AV+BV)/2)x100 Study/Chart Alerts And Scanning: Available Main Price Graph Identifiers/Variables |
[2023-03-27 14:58:14] |
John - SC Support - Posts: 39428 |
In addition to Post #2, you would use the Spreadsheet Formula to do the calculation. Refer to the following: Spreadsheet Formula For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-31 17:11:49] |
thank you both
