Date/Time: Tue, 22 Apr 2025 23:08:10 +0000
Keep Text on screen when Increasing bar spacing?
View Count: 440
[2023-03-25 18:29:49] |
58LesPaul - Posts: 429 |
I have a Watch List of ETF's and a text on each one near the top stating what industry the specific ETF represents. When I increase bar spacing the text disappears. Is there any way to lock the text at one spot on the chart and it not move when changing bar spacing? I'm using the Symbol Display which keeps the symbol in the same spot but the text for the industry name keeps moving around. Of course, locking the drawing does not accomplish this.
[2023-03-26 10:18:19] |
Sierra_Chart Engineering - Posts: 19305 |
You can use the Symbol Display study and use the "Alternate Symbol Text" Input to display whatever you want. You can also use the Stationary Text tool. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
