Date/Time: Tue, 22 Apr 2025 23:22:03 +0000
Replay control Window won’t appear
View Count: 569
[2023-03-25 02:35:58]
jaxscott - Posts: 57
My replay control window will not appear for me anymore. Pressing Reset Windows doesn’t solve the issue as it usually has in the past. Any tips on how to solve?
[2023-03-25 04:03:21]
ondafringe - Posts: 322
Have you tried Chart > Replay Chart > Reset Replay Control Panel Window
[2023-03-25 08:00:24]
Sierra_Chart Engineering - Posts: 19305
Yes use the command given in post #2.
[2023-03-27 05:03:04]
Always the obvious solution that is the last to be looked at... Thx!
