Date/Time: Tue, 26 Nov 2024 20:12:59 +0000
Region dividing line - distance
View Count: 2041
[2014-06-18 16:42:08] |
User53601 - Posts: 105 |
Hello, Is it possible to reduce the distance from Region dividing line, as showed in the picture? The reason I am asking is a situation, when the chart/window is small. Every piece of place is helpful to perceive the histogram. Jaro |
Region dividing line distance.png / V - Attached On 2014-06-18 16:42:00 UTC - Size: 76.84 KB - 518 views |
[2014-06-18 16:47:58] |
Yes. This can be done through Chart >> Chart Settings>> Advanced Settings 2 >> Region Data Lines. You need to set it to Overlapped for Region 2.
[2014-06-18 17:45:40] |
Helped. Thanks a lot. |
