Date/Time: Tue, 22 Apr 2025 23:16:48 +0000
compare POC between two consecutive bars
View Count: 501
[2023-03-24 20:07:46] |
User970210 - Posts: 100 |
Hi, the condition show no/wrong result that compares bar POC between two consecutive bars. please advice. thx |
[2023-03-24 23:29:04] |
John - SC Support - Posts: 39428 |
We are not understanding. Do you have a condition that you have written that is not working? Or are you looking for how to write a condition? If the latter, then what exactly do you want to compare and what do you want to have happen? Is this an alert, or in a spreadsheet? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-25 17:14:45] |
thanks for reply. I have created alert using POC of 1min for each bar, then alert as =AND(C>ID1.SG2[-1],ID1.SG2>ID1.SG2[-1]). then I found out the condition become true SOMETIME even when one equation is true instead of both true. it happens in 5min as well 30min bar. I make sure value format is inherited that does not help either. I also checked on chart value windows to make sure the case. please advice. |
[2023-03-27 14:42:28] |
We find it very hard to believe that the condition is true without both conditions being true. Can you please give us a screenshot of where you see this occur? Also, what is the study that is ID1? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-27 16:03:32] |
please check the screenshot https://www.sierrachart.com/image.php?Image=1679931803199.png panel 3 condition =AND(C>ID10.SG2[-1],ID10.SG2>ID10.SG2[-1]) panel 4 condition =ID10.SG2<ID10.SG2[-1] apparently both conditions can not be true at same time for last bar and third bar from right. |
[2023-03-27 16:45:26] |
What is the study that you are testing (what study is ID10)? Also, the image is too busy, we have no idea what is occurring at any given bar. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-27 18:36:40] |
ID10.SG2 is 1min POC, that shown as yellow dash for that bar. I used alert condition for panel 3, 4 to cross check each other. most time they are in same color, but sometimes they are not. based on my condition, panel 3 and 4 should not be different color for the same bar. it happens regardless the time period for charts since I can find them in 5min, 30min as well as 4 hr.
[2023-03-27 21:46:15] |
What is the exact name of the study that you are using to get the POC (i.e. what is the name of the study for ID10)?
[2023-03-28 01:26:20] |
volume by price study. draw mode as POC,VAH,VAL.VWAP Lines only
[2023-03-28 15:47:44] |
We are not sure why you are having an issue. From what you state, it should be working. We do wonder if your Volume by Price is setup properly, as that is one of the few things we can think of that could cause things to be off. But, if you are wanting to get the POC for every bar, then the study Volume Point of Control for Bars is a better study to use than the VbP. Refer to the information here: Volume Point of Control for Bars Try using that study instead and see how things work out. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-28 19:50:35] |
thank for your reply. I will give it a try.
[2023-03-28 20:36:03] |
I just tried with volume point of control for bars study. Unfortunately the result is the same. for some reason that both logic for this case give true even only one of two conditions is true.
[2023-03-28 20:51:44] |
Please get us the chart by following these instructions and we will take a look: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-29 19:58:39] |
I found out the study interfered with the questioned study after following your advice to remove all other studies. thank you very much for your help again.
