Date/Time: Wed, 27 Nov 2024 23:49:28 +0000
Extend POC, VWAP, VA do not appear when Keeping Zoom in
View Count: 606
[2023-03-24 18:55:05] |
NanWangIDa - Posts: 10 |
Hello Support, I use VBP study and extend POC, VWAP, VA (Extend to Both Window Edges) and it works. However when I zoom in the chart gradually, some extend POC, VWAP, VA (I guess they are very few days ago) will disappear, when I zoom out gradually those disappear extend POC, VWAP, VA will appear agian. I want to ask how to let all of them always appear even when I gradually zoom in the chart. |
[2023-03-26 13:53:32] |
Hello Support, this is a short record to show you, please see it to the end, thanks.
[2023-03-27 14:19:57] |
Sierra_Chart Engineering - Posts: 17198 |
Provide us a chart which shows this and tell us the specific Date of the volume profile that has this issue and we will look at it. Instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-27 14:20:16
[2023-03-27 19:11:46] |
Hello Support, when you open chart book, you will see two white horizontal line: The one value 4027.25 is the value of VWAP form 2023/3/22, you will see the VBP extend VWAP yellow line when you gradually zoom out, but when you gradually zoom in this VBP extend VWAP yellow line will disappear agian. The second value 4031 is the value of POC from 2023/3/22, you will see the VBP extend POC purple line when you gradually zoom out, but when you gradually zoom in this VBP extend POC purple line will disappear agian. I want to keep them always in view at current trading day. |
Private File |
[2023-03-28 07:10:50] |
Ok we will look this over. But we are very busy and we do not know how soon we can get to it. It can be several weeks.
[2023-04-17 10:42:44] |
We are looking at this now.
[2023-04-20 06:39:29] |
We looked into this and it is by design that when extending the value area, point of control or volume weighted average price lines to the window edges, that this only occurs for volume periods that are at least partially visible. This is by design for performance reasons and will not change. We have added a new extension option to extend to the right window edge for all profiles. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-20 07:04:51] |
Hello Support, where can I find the new extension option to extend to the right window edge for all profiles?
[2023-04-20 08:44:37] |
It will be in the next release which we can put out in a day or two. It was completed early this morning.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-04-20 08:44:44
[2023-06-20 00:01:51] |
James A Adams - Posts: 13 |
Hello, I am trying to enable this Extend to edge of window - all profiles, But i do NOT want profiles to be shown, Only the lines. When I choose volume by price setting "POC, VAH, VAL, VWAP lines only", the extensions do not work. But they do show when the profiles ARE enabled. Can this be made possible for the extension lines to show when we have the "Lines only" setting enabled please. I just want to see where value is, but the profiles end up cluttering the screen. Thank you.
[2023-06-20 13:40:52] |
In this case you need to set this Volume by Price study Input to Blank: Volume By Price Study: Volume Bars Draw Method Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
