Date/Time: Tue, 22 Apr 2025 23:38:39 +0000
trying to download software having problems
View Count: 357
[2023-03-24 18:35:09]
User300984 - Posts: 1
Hi just bought a new computer, trying to download software having problems
Coming out with
Error serving, download file to location system shopping installation, check login press, install to retry
I am using a Mac with Windows, 11 through parallels do you have any advice to overcome this please?
Kind regards, Simon Payne
Private File
[2023-03-24 22:38:26]
Sierra_Chart Engineering - Posts: 19307
The installation path is set incorrectly.
On a Windows computer typically the installation path will be C:\SierraChart
Date Time Of Last Edit: 2023-03-24 22:38:31
