Date/Time: Tue, 22 Apr 2025 23:24:45 +0000
Bar print
View Count: 367
[2023-03-24 18:10:01]
User585104 - Posts: 148
Maybe an odd question but, I use number of trades/tick chart. Is there a way to set SC up so it prints the bar only when it is completed? Meaning I dont want to see it forming, I want the bar to appear when it is full.
The reason I ask is in replay in bar by bar mode I can flick through any ES day like lightning in a matter of minutes and get 50-100 points literally without even thinking but live I cant get anywhere near the success rate. It's not about it being live and stress because of the the money because the money is irrelevant and I use a naked chart, so its nothing to do with any studies etc.
It is seeing those bars forming in slow motion that makes my brain overcalculate/over think what is going on you dig?
Any solution or work around? Or how to I set a beep up on bar close?
Date Time Of Last Edit: 2023-03-24 20:10:39
[2023-03-24 23:21:15]
John - SC Support - Posts: 39428
Use the Color Bar Based on Alert Condition and set the following:
- Number of Bars to Calculate: 1
- Automatically Clear From Before 'Number of Bars to Calculate': Yes
On the Subgraphs tab, set the color of the Color Bar subgraph to be the same as your background
On the Alerts tab, set the following for the alert:
=1
If this is setup properly, then you will not see the current bar until the next bar starts.
