Date/Time: Tue, 26 Nov 2024 20:40:40 +0000
Candle Lagging Price
View Count: 1534
[2014-06-18 14:06:32]
ged - Posts: 233
I have SC Real Time Data and IB.
Trading CL, I am seeing about a 2 to 3 second lag from a change in price to the updating of my candle. My chart price and IB's price appear to be in sync, but my chart candles are not.
I have unchecked the option to record historical data in real time.
Would appreciate your thoughts.
[2014-06-18 16:26:03]
Do you see an [M] after the symbol on the top line of the CL chart?
[2014-06-18 16:34:53]
ged - Posts: 233
No. As I subscribe for the full CME Futures Group thru SC, what do I need to do to pick up the SC data rather than IB data (if that is what is happening).
I have seen the 'M' in the past, don't know why it is not there now.
Date Time Of Last Edit: 2014-06-18 16:46:47
[2014-06-18 16:50:12]
Restart Sierra Chart. Open a chart for the CL futures contract and post a copy of the Message Log by following these instructions:
https://www.sierrachart.com/index.php?l=PostingInformation.php#log
Also, make sure you are connected to your Interactive Brokers Live account.
Date Time Of Last Edit: 2014-06-18 16:51:21
[2014-06-18 16:56:20]
ged - Posts: 233
I am under the impression that SC data should be received in my IB sim account, so long as I have also utilized my live IB account during the same month. Is this correct?
[2014-06-18 17:00:41]
Yes. Have you connected Sierra Chart at least once this month to your Live account.
[2014-06-18 17:03:51]
ged - Posts: 233
Yes.
[2014-06-18 17:11:02]
We need to see the Message Log. Provide it by following these instructions:
[2014-06-18 17:22:58]
ged - Posts: 233
Here is the log:
Software version: 1143 | 2014-06-18 10:17:45
Usage end date: 2014-07-31 | 2014-06-18 10:17:45
Enabled for: Advanced Features. | 2014-06-18 10:17:45
Enabled for: Sierra Chart Historical Data Service. | 2014-06-18 10:17:45
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2014-06-18 10:17:45
Enabled for: CME, CBOT, NYMEX, COMEX exchanges. | 2014-06-18 10:17:45
Enabled for: US EQUITIES exchanges. | 2014-06-18 10:17:45
Received 1 data feed usernames. | 2014-06-18 10:17:45
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-06-18 10:17:45
Active service: Interactive Brokers | 2014-06-18 10:17:45
Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-06-18 10:17:45
2014-06-18 10:17:45 Local computer clock time | 2014-06-18 10:17:45
2014-06-18 17:17:45 GMT time | 2014-06-18 10:17:45
2014-06-18 10:17:45 Time zone adjusted time | 2014-06-18 10:17:45
Time difference to server time: 1 seconds. | 2014-06-18 10:17:45
Program path: C:\SierraChart\ | 2014-06-18 10:17:45
Data Files path: C:\SierraChart\Data\ | 2014-06-18 10:17:45
OS Version Number: 6.1 | 2014-06-18 10:17:45
Checking for new symbol settings for ib | 2014-06-18 10:17:45
Symbol settings are up-to-date for ib | 2014-06-18 10:17:45
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-06-18 10:17:50
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-18 10:17:51
Socket has been shutdown and closed. | 2014-06-18 10:17:51
Failed to connect to the data and trade server. | 2014-06-18 10:17:51
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-06-18 10:17:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-18 10:17:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-18 10:17:51
Disconnected from IB. | 2014-06-18 10:17:51
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-18 10:17:51
Starting TWS auto-login thread. | 2014-06-18 10:17:54
TWS auto-login thread ending. | 2014-06-18 10:17:54
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-06-18 10:17:56
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-18 10:17:57
Socket has been shutdown and closed. | 2014-06-18 10:17:57
Failed to connect to the data and trade server. | 2014-06-18 10:17:57
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-06-18 10:17:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-18 10:17:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-18 10:17:57
Disconnected from IB. | 2014-06-18 10:17:57
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-18 10:17:57
Mapping CL-201408-NYMEX to CLQ4. Service code: nymex | 2014-06-18 10:17:57
HD Request # 2 - Downloading Intraday chart data for CL-201408-NYMEX to the file CL-201408-NYMEX.scid. Service: nymex | 2014-06-18 10:17:57
HD Request # 2 - Download start Date-Time: 2014-06-18 10:10:00.0 | 2014-06-18 10:17:57
HD Request # 2 - Using server: scdf2.sierracharts.com port 10149 | 2014-06-18 10:17:57
Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-06-18 10:17:57
The network socket is connected. | 2014-06-18 10:17:57
HD Request # 2 - Sending historical data logon request message. | 2014-06-18 10:17:57
HD Request # 2 - Requesting Intraday data. Start Date-Time: 2014-06-18 10:10:00. Record interval: 0 . Symbol: CLQ4 | 2014-06-18 10:17:57
HD Request # 2 - Decompressing data. | 2014-06-18 10:17:57
The network socket for historical data has been closed. | 2014-06-18 10:17:57
HD Request # 2 - Historical data for CL-201408-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-06-18 10:17:59
HD Request # 2 - Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CL-201408-NYMEX | 2014-06-18 10:17:59
HD Request # 2 - Intraday download COMPLETE for CL-201408-NYMEX. Completion time: 2s | 2014-06-18 10:17:59
Chart #4 has tagged chart #2 for full recalculation. Chartbook: rMBP SC Data IB Paper.cht | 2014-06-18 10:17:59
Mapping TSLA to TSLA. Service code: equities.us | 2014-06-18 10:17:59
HD Request # 3 - Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: equities.us | 2014-06-18 10:17:59
HD Request # 3 - Download start Date-Time: 2014-06-18 10:10:53.0 | 2014-06-18 10:17:59
HD Request # 3 - Using server: scdf1.sierracharts.com port 10149 | 2014-06-18 10:17:59
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: rMBP SC Data IB Paper.cht | 2014-06-18 10:17:59
Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-06-18 10:17:59
The network socket is connected. | 2014-06-18 10:17:59
HD Request # 3 - Sending historical data logon request message. | 2014-06-18 10:17:59
Starting TWS auto-login thread. | 2014-06-18 10:17:59
TWS auto-login thread ending. | 2014-06-18 10:17:59
HD Request # 3 - Requesting Intraday data. Start Date-Time: 2014-06-18 10:10:53. Record interval: 0 . Symbol: TSLA | 2014-06-18 10:18:00
HD Request # 3 - Decompressing data. | 2014-06-18 10:18:00
HD Request # 3 - Receiving Intraday data for TSLA starting at 2014-06-18 10:10:53 | 2014-06-18 10:18:00
HD Request # 3 - Timestamp of first Intraday data file record written: 2014-06-18 10:10:53 | 2014-06-18 10:18:00
Socket has been shutdown and closed. | 2014-06-18 10:18:00
HD Request # 3 - Historical data for TSLA is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-06-18 10:18:00
The network socket for historical data has been closed. | 2014-06-18 10:18:00
HD Request # 3 - Received 196 records from 2014-06-18 10:10:53 to 2014-06-18 10:17:57 (7.1 minutes) and wrote 186 records for TSLA | 2014-06-18 10:18:00
HD Request # 3 - Intraday download COMPLETE for TSLA. Completion time: 1s | 2014-06-18 10:18:00
Starting TWS auto-login thread. | 2014-06-18 10:18:02
TWS auto-login thread ending. | 2014-06-18 10:18:02
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-06-18 10:18:02
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-18 10:18:03
Socket has been shutdown and closed. | 2014-06-18 10:18:03
Failed to connect to the data and trade server. | 2014-06-18 10:18:03
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-06-18 10:18:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-18 10:18:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-18 10:18:03
Disconnected from IB. | 2014-06-18 10:18:03
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-18 10:18:03
Starting TWS auto-login thread. | 2014-06-18 10:18:06
TWS auto-login thread ending. | 2014-06-18 10:18:06
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-06-18 10:18:08
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-18 10:18:09
Socket has been shutdown and closed. | 2014-06-18 10:18:09
Failed to connect to the data and trade server. | 2014-06-18 10:18:09
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-06-18 10:18:09
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-18 10:18:09
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-18 10:18:09
Disconnected from IB. | 2014-06-18 10:18:09
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-18 10:18:09
Starting TWS auto-login thread. | 2014-06-18 10:18:10
TWS auto-login thread ending. | 2014-06-18 10:18:10
Starting TWS auto-login thread. | 2014-06-18 10:18:14
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-06-18 10:18:14
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-18 10:18:15
Socket has been shutdown and closed. | 2014-06-18 10:18:15
Failed to connect to the data and trade server. | 2014-06-18 10:18:15
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-06-18 10:18:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-18 10:18:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-18 10:18:15
Disconnected from IB. | 2014-06-18 10:18:15
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-18 10:18:15
TWS auto-login thread ending. | 2014-06-18 10:18:16
Starting TWS auto-login thread. | 2014-06-18 10:18:18
TWS auto-login thread ending. | 2014-06-18 10:18:18
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-06-18 10:18:20
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-18 10:18:21
Socket has been shutdown and closed. | 2014-06-18 10:18:21
Failed to connect to the data and trade server. | 2014-06-18 10:18:21
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-06-18 10:18:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-18 10:18:21
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-18 10:18:21
Disconnected from IB. | 2014-06-18 10:18:21
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-18 10:18:21
Starting TWS auto-login thread. | 2014-06-18 10:18:22
TWS auto-login thread ending. | 2014-06-18 10:18:22
Starting TWS auto-login thread. | 2014-06-18 10:18:26
TWS auto-login thread ending. | 2014-06-18 10:18:26
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-06-18 10:18:26
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-18 10:18:27
Socket has been shutdown and closed. | 2014-06-18 10:18:27
Failed to connect to the data and trade server. | 2014-06-18 10:18:27
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-06-18 10:18:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-18 10:18:27
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-18 10:18:27
Disconnected from IB. | 2014-06-18 10:18:27
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-18 10:18:27
Starting TWS auto-login thread. | 2014-06-18 10:18:30
TWS auto-login thread ending. | 2014-06-18 10:18:30
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-06-18 10:18:32
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-06-18 10:18:33
Socket has been shutdown and closed. | 2014-06-18 10:18:33
Failed to connect to the data and trade server. | 2014-06-18 10:18:33
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-06-18 10:18:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-06-18 10:18:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-06-18 10:18:33
Disconnected from IB. | 2014-06-18 10:18:33
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-06-18 10:18:33
Starting TWS auto-login thread. | 2014-06-18 10:18:34
TWS auto-login thread ending. | 2014-06-18 10:18:34
Starting TWS auto-login thread. | 2014-06-18 10:18:38
TWS auto-login thread ending. | 2014-06-18 10:18:38
Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-06-18 10:18:38
The network socket is connected. | 2014-06-18 10:18:38
Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-06-18 10:18:38
TWS server version: 70 | 2014-06-18 10:18:38
IB: Connected. Waiting for account information. | 2014-06-18 10:18:38
IB Account information received. | 2014-06-18 10:18:38
Connected to IB Demo or Simulated account. | 2014-06-18 10:18:38
Interactive Brokers: Requesting Trade Positions for account: DU148803 | 2014-06-18 10:18:38
Next valid order ID: 10089 | 2014-06-18 10:18:38
Message from IB: Market data farm connection is broken:usfuture. IB Error Code: 2103. Request ID: -1. | 2014-06-18 10:18:38
NOTICE: Not connected to Live trading account to receive CME real-time futures data. | 2014-06-18 10:18:38
Interactive Brokers: Received Trade Positions download end message for account DU148803 | 2014-06-18 10:18:38
Interactive Brokers - Starting real-time market data updates for: CL-201408-NYMEX. ID: 1 | 2014-06-18 10:18:38
Subscribing to real-time True Data for symbol: CL SecType: FUT Exchange: NYMEX Currency: | 2014-06-18 10:18:38
Subscribing to symbol: CL SecType: FUT Expiry: 201408 Exchange: NYMEX Currency: Multiplier: | 2014-06-18 10:18:38
Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2014-06-18 10:18:38
HD Request # 4 - Downloading Intraday chart data for CL-201408-NYMEX to the file CL-201408-NYMEX.scid. Service: nymex | 2014-06-18 10:18:38
HD Request # 4 - Download start Date-Time: 2014-06-18 10:10:00.0 | 2014-06-18 10:18:38
Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2014-06-18 10:18:38
HD Request # 4 - Using server: scdf2.sierracharts.com port 10149 | 2014-06-18 10:18:38
Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-06-18 10:18:38
Mapping TSLA to TSLA. Service code: equities.us | 2014-06-18 10:18:38
SC Exchange Data - Starting real-time market data updates for: TSLA. ID: 2 | 2014-06-18 10:18:38
Using username 0 | 2014-06-18 10:18:38
SC Exchange Data: Connecting to the server scdf2.sierracharts.com. Port 10047 | 2014-06-18 10:18:38
HD Request # 4 - Sending historical data logon request message. | 2014-06-18 10:18:38
Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-06-18 10:18:39
The network socket is connected. | 2014-06-18 10:18:39
SC Exchange Data: Connected to server. | 2014-06-18 10:18:39
SC Exchange Data: Sending logon request message. | 2014-06-18 10:18:39
Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2014-06-18 10:18:39
HD Request # 4 - Requesting Intraday data. Start Date-Time: 2014-06-18 10:10:00. Record interval: 30 . Symbol: CLQ4 | 2014-06-18 10:18:40
SC Exchange Data Server Info - Server Name: . Server Version: . Provider Name: . | 2014-06-18 10:18:40
SC Exchange Data - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-06-18 10:18:40
SC Exchange Data - Successfully connected. | 2014-06-18 10:18:40
SC Exchange Data - Restarting real-time data updates for symbol: TSLA -> TSLA | 2014-06-18 10:18:40
HD Request # 4 - Decompressing data. | 2014-06-18 10:18:40
Socket has been shutdown and closed. | 2014-06-18 10:18:40
The network socket for historical data has been closed. | 2014-06-18 10:18:40
HD Request # 4 - Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CL-201408-NYMEX | 2014-06-18 10:18:40
HD Request # 4 - Intraday download COMPLETE for CL-201408-NYMEX. Completion time: 2s | 2014-06-18 10:18:40
Real-time Intraday chart data file updates started for CL-201408-NYMEX | 2014-06-18 10:18:40
HD Request # 5 - Downloading Intraday chart data for CL-201408-NYMEX to the file CL-201408-NYMEX.scid. Service: ib | 2014-06-18 10:18:40
HD Request # 5 - Download start Date-Time: 2014-06-18 10:10:00.0 | 2014-06-18 10:18:40
HD Request # 5 - Requesting a total of 0 days and 5320 seconds. | 2014-06-18 10:18:40
HD Request # 5 - IB Backfill - Seconds requested: 5320. Seconds Remaining: 0. | 2014-06-18 10:18:40
HD Request # 5 - Requesting 5320 Seconds of data at 30 secs with ending Date-Time at 2014-06-18 11:28:40 for CL-201408-NYMEX | 2014-06-18 10:18:40
HD Request # 6 - Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: equities.us | 2014-06-18 10:18:40
HD Request # 6 - Download start Date-Time: 2014-06-18 10:17:57.0 | 2014-06-18 10:18:40
HD Request # 6 - Using server: scdf1.sierracharts.com port 10149 | 2014-06-18 10:18:40
Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-06-18 10:18:40
The network socket is connected. | 2014-06-18 10:18:40
HD Request # 6 - Sending historical data logon request message. | 2014-06-18 10:18:40
HD Request # 6 - Requesting Intraday data. Start Date-Time: 2014-06-18 10:17:57. Record interval: 0 . Symbol: TSLA | 2014-06-18 10:18:40
HD Request # 6 - Decompressing data. | 2014-06-18 10:18:40
HD Request # 6 - Receiving Intraday data for TSLA starting at 2014-06-18 10:17:57 | 2014-06-18 10:18:40
HD Request # 6 - Timestamp of first Intraday data file record written: 2014-06-18 10:18:01 | 2014-06-18 10:18:40
HD Request # 6 - Received 28 records from 2014-06-18 10:17:57 to 2014-06-18 10:18:37 (40.0 seconds) and wrote 21 records for TSLA | 2014-06-18 10:18:40
HD Request # 6 - Intraday download COMPLETE for TSLA. Completion time: 0s | 2014-06-18 10:18:40
Real-time Intraday chart data file updates started for TSLA | 2014-06-18 10:18:40
Chart #4 has tagged chart #2 for full recalculation. Chartbook: rMBP SC Data IB Paper.cht | 2014-06-18 10:18:40
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: rMBP SC Data IB Paper.cht | 2014-06-18 10:18:40
HD Request # 5 - Processing historical data message from TWS | 2014-06-18 10:18:41
HD Request # 5 - Receiving Intraday data for CL-201408-NYMEX starting at 2014-06-18 10:00:30 | 2014-06-18 10:18:41
HD Request # 5 - Timestamp of first Intraday data file record written: 2014-06-18 10:10:30 | 2014-06-18 10:18:41
HD Request # 5 - Received 38 records and wrote 17 records from 2014-06-18 10:00:00 to 2014-06-18 10:18:30. | 2014-06-18 10:18:41
Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2014-06-18 10:18:41
HD Request # 5 - Received 38 records from 2014-06-18 10:00:30 to 2014-06-18 10:18:30 (18.0 minutes) and wrote 17 records for CL-201408-NYMEX | 2014-06-18 10:18:42
HD Request # 5 - Intraday download COMPLETE for CL-201408-NYMEX. Completion time: 2s | 2014-06-18 10:18:42
Real-time Intraday chart data file updates started for CL-201408-NYMEX | 2014-06-18 10:18:42
Chart #4 has tagged chart #2 for full recalculation. Chartbook: rMBP SC Data IB Paper.cht | 2014-06-18 10:18:42
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: rMBP SC Data IB Paper.cht | 2014-06-18 10:18:42
IB: Requesting historical order fills for account DU148803 | 2014-06-18 10:18:43
Interactive Brokers: Received Open orders end message. | 2014-06-18 10:18:43
[2014-06-18 17:28:38]
This is the problem:
We know you said you connected to the live account previously, but without knowing exactly what you did previously, you need to do it again.
[2014-06-18 17:29:35]
ged - Posts: 233
It has occurred to me that since I use different instances of SC for live and paper trading, and I have only logged into IB live in the one instance, and only into IB sim in the other instance, that perhaps this is the problem.
I will disable auto log in to IB in my IB sim instance of SC; then manually log into my live account there, and see if that clears up the problem.
[2014-06-18 17:39:51]
Yes, this explains why you have this problem. You need to connect your Live account once a month in the instance of Sierra Chart where you want to get the real-time futures data feed.
[2014-06-18 17:40:53]
ged - Posts: 233
That was my problem. Thanks.
[2014-06-18 17:49:28]
ged - Posts: 233
Last post deleted; new thread started.
Date Time Of Last Edit: 2014-06-18 18:02:36
