Date/Time: Thu, 28 Nov 2024 09:56:20 +0000
[Programming Help] - s_VolumeLevelAtPrice Compilation error
View Count: 384
[2023-03-24 17:24:27]
User411647 - Posts: 19
Hi guys
Its not possible compilate this code....
Before compil. without errors
Any solution please ??
s_VolumeLevelAtPrice* p_VolumeLevelAtPrice = nullptr;
  int BarIndex = sc.Index;
  int VAPSizeAtBarIndex = sc.p_VolumeLevelAtPriceForBars->GetSizeAtBarIndex(BarIndex);
  unsigned int MaxTradeVol = 0;
  float MaxTradePrice = 0.0f;
  for (int VAPIndex = 0; VAPIndex < VAPSizeAtBarIndex; VAPIndex++) {
    if (!sc.p_VolumeLevelAtPriceForBars->GetVAPElementAtIndex(BarIndex, VAPIndex, &p_VolumeLevelAtPrice))
      break;
    unsigned int maxTradeVolAtPrice = sc.p_VolumeLevelAtPriceForBars->GetMaxVolumeAtPrice(BarIndex, p_VolumeLevelAtPrice->PriceInTicks);
    if (maxTradeVolAtPrice > MaxTradeVol)
      MaxTradeVol = maxTradeVolAtPrice;
      MaxTradePrice = sc.TicksToPriceValue(p_VolumeLevelAtPrice->PriceInTicks);
1>Dll18.obj : error LNK2019: Nerozpoznaný externí symbol _CrtDbgReport odkazovaný ve funkci "void __cdecl std::_Verify_range<struct s_VolumeLevelAtPrice>(struct s_VolumeLevelAtPrice const * const,struct s_VolumeLevelAtPrice const * const)" (??$_Verify_range@Us_VolumeLevelAtPrice@@@std@@YAXQEBUs_VolumeLevelAtPrice@@0@Z)
1>..\..\..\..\..\..\SierraChartWithCQG\Data\Dll18.dll : fatal error LNK1120: Počet nerozpoznaných externích typů: 1
1>Sestavení projektu Dll18.vcxproj bylo dokončeno: CHYBA.
========== Nové sestavení: úspěšná: 0, neúspěšná: 1, přeskočilo se: 0 ==========
[2023-05-07 12:14:51]
Sierra_Chart Engineering - Posts: 17201
It is hard to understand what the error is because it is not in English.
We are not understanding what the error is here. Can you translate this.
[2023-05-07 15:38:26]
Hi
I had a similar problem with VS2017, now Iam using VS2022 and changing the runtime library setting to /Mtd solved the problem
Now compil without problems
regards
