Date/Time: Tue, 22 Apr 2025 22:59:31 +0000
Denali feed and order fills
View Count: 285
[2023-03-24 14:42:33] |
User449884 - Posts: 169 |
I only have CQG feed. Does not having the denali feed affect the speed of fills ?
[2023-03-24 16:27:50] |
Sierra_Chart Engineering - Posts: 19305 |
There is no effect on the speed of the fills depending on the data feed being used. You will get the fastest fills with Teton order routing: Sierra Chart Teton Futures Order Routing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-24 16:28:30
