Date/Time: Tue, 22 Apr 2025 22:43:05 +0000
Chart Calculator Tool & "After Single Tool Use" Setting
View Count: 501
[2023-03-24 14:41:05] |
TraderBiku - Posts: 37 |
Hello - I currently am using the "After Single Tool Use Change To (Global Settings >> Tool Settings >> General >> Tool Options)" function set to "Pointer", and it appears to work for all the tools I regularly use, but the Chart Calculator tool remains active after a single use (instead of reverting to the Pointer tool as it does for other tools) and requires that I manually revert to the Pointer function - is there a way to make it revert to Pointer after single use as well? Thank you! |
[2023-03-24 22:51:02] |
John - SC Support - Posts: 39428 |
We are not able to reproduce this. When we use the Chart Calculator tool, after placing the second point, the tool reverts to what is set for "After Single Tool Use Change To". Are you possibly not actually placing the second data point, but then right-clicking to exit the tool, as you may just want to see something quickly and not keep it on the chart? This would not initiate the change to the Pointer if you are doing this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-25 00:26:38] |
You're absolutely right John, that is what I was doing and not even aware of it - apologies.
