Date/Time: Tue, 22 Apr 2025 23:24:46 +0000
[User Discussion] - Trade Activity Log
View Count: 372
[2023-03-24 12:43:20] |
User657837 - Posts: 6 |
Each day by default my trade statistics & trade activity log are disabled. I have to go an uncheck both boxes for some reason. How do I make these stay enabled everytime I login? Thanks
[2023-03-24 16:22:58] |
Sierra_Chart Engineering - Posts: 19306 |
This occurs because you are using Risk Manager Mode: Trade Account and Risk Management: Setting Sierra Chart to Risk Manager Mode You need to disable that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
