Date/Time: Mon, 21 Apr 2025 23:36:06 +0000
Copy Drawing's to a Different Symbol
View Count: 587
[2023-03-24 11:45:08]
User871209 - Posts: 91
I am trying to copy drawrings made on a ES chart to a NQ chart that has the same time frame but they will not copy from one chart to the other.
I have checked the Show Chart Drawings For Different Symbols is Enabled
But they don't show up.
Can you please tell me if there is anything I am missing to be able to do this?
Thanks,
[2023-03-24 16:45:48]
Sierra_Chart Engineering - Posts: 19290
This is not going to work properly because the symbols are different. Therefore, the drawings will not be in the same place. They will be at different prices.
[2023-03-25 08:33:41]
Thank you for your reply,
Would there be a possibility to copy the drawing from Micro ES June contract to Micro ES September contract as they have a close correlation in price?
Please let me know,
Regards,
[2023-03-25 19:08:28]
Yes but the drawings will not be aligned properly.
[2025-02-08 19:41:24]
User601016 - Posts: 22
Hi John/SC Engineering!
I have NQ and MNQ in separate chart books. Is it possible to keep these NQ and MNQ chart drawings in sync all the time ie. if i add/modify/delete chart drawings in NQ chartbook, it changes accordingly in MNQ chart book and visa-versa?
I created MNQ chartbook by duplicating NQ and then changing all its symbols to MNQ. In MNQ chartbook's charts I tried chart settings>> Chart Drawings >> show chart drawings for different symbols = 'Yes'. It worked (seems to be a one time deal). Now i have 2 separate NQ and MNQ chart books but any changes in one chartbook drawings is not reflected in the other chart book.
Thank You!
[2025-02-09 01:05:58]
You can copy the Chart drawings to different Chartbooks. Refer to:
Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu)
