Date/Time: Tue, 22 Apr 2025 23:02:14 +0000
Using delayed data
View Count: 434
[2023-03-24 09:10:46] |
User266447 - Posts: 270 |
Is it possible for April to use delay data only?
[2023-03-24 09:14:55] |
Sierra_Chart Engineering - Posts: 19305 |
Yes you can use delayed data at any time. Set this setting to No: Data/Trade Service Settings: Allow Support for Sierra Chart Data Feeds (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings) And be sure to reconnect to the data feed after. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-24 09:15:22
