Date/Time: Tue, 22 Apr 2025 22:45:51 +0000
Changing symbol but keeping the same chart settings
View Count: 501
[2023-03-23 23:16:50]
ssangha84 - Posts: 128
Hello, I recently changed brokers and had to add a new symbol for the ES. Whenever I try to however, it just opens in a new window, with all default chart settings. How can I make it so that the new symbol has all of the exact same chart settings, including all of the same linked charts? Thank you.
[2023-03-24 01:38:22]
Tony - Posts: 565
On your old chart that has all the settings you want:
Chart --> Chart Settings --> Symbol
Change the symbol there, instead opening a new intraday chart (new window)
[2023-03-24 16:37:23]
Sierra_Chart Engineering - Posts: 19305
Refer to:
Using Chart Templates
