Date/Time: Tue, 22 Apr 2025 23:27:19 +0000
IBR EXTENSION
View Count: 790
[2023-03-23 15:49:30] |
ell9991 - Posts: 7 |
i am using the TPO market profile, can someone tell me what the IBR extension percentage horizontal lines mean? green and red colors? thanks Date Time Of Last Edit: 2023-03-23 15:50:57
![]() Attachment Deleted. |
[2023-03-23 16:28:12] |
John - SC Support - Posts: 39428 |
The Initial Balance Range is the range of the prices over a certain period of time starting at the beginning of the trading day (either starting with Evening session or Regular session, depending on your settings). You can extend the amount of that range by a certain percentage using the IBR extensions. Refer to the information here: Time Price Opportunity (TPO) Profile Charts: Initial Balance Range For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
