Date/Time: Tue, 22 Apr 2025 23:05:28 +0000
Convert chartbook?
View Count: 333
[2023-03-22 22:31:03]
jradpgh - Posts: 2
ChartBook fails to import with a message that it's not compatible. Can support help to convert?
The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it. File: C:\Users\jseaton\Desktop\OR_BreakOUT_MultiDOM.Cht | 2023-03-22 22:24:28.901 *
Date Time Of Last Edit: 2023-03-22 23:04:19
Private File
[2023-03-23 13:12:19]
John - SC Support - Posts: 39428
The instructions to update the chartbook are at the following link:
Chartbooks (Workspaces): Opening Older Chartbooks
