Date/Time: Tue, 22 Apr 2025 18:33:47 +0000
TRADE WINDOWS
View Count: 311
[2023-03-22 16:33:08] |
User344478 - Posts: 161 |
All three fields in Trade Windows are empty 1. Pos Qty @ Price, 2. The Open Profit/Loss, 3. The Daily Profit/Loss.
[2023-03-22 19:55:42] |
John - SC Support - Posts: 39418 |
Empty - as in you can not see anything in those fields, not even the statement "P/L 0.00"? If this is the case, then it sounds like the text color got changed to be the same as the background. Open Global Settings >> Graphics Settings and look for the entry Chart Trade Window Position and P/L Text Color and make sure this is set to the color you want relative to the background for those fields (note that there are multiple background options depending on the Trade Type or Profit/Loss). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
