Date/Time: Tue, 22 Apr 2025 22:45:51 +0000
Can't load more that 10 days on chart.
View Count: 418
[2023-03-22 15:44:16] |
Hofmeister - Posts: 27 |
Hello, I'm trying to make an hourly that is fixed to 14 days worth of data. The trouble I'm having is its only allowing me to use 10 days of data and while I can go lower, I can't go any higher. I'd also like to having the chart auto fit everything, its mainly do see all the of the volume profile data. Just looking for help. Thanks |
[2023-03-22 19:06:59] |
John - SC Support - Posts: 39428 |
You were limited because you were on a standard Trial, you had not activated the trial to allow you all the capabilities. We have activated the trial for your account. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-22 22:56:36] |
Thank You it works now. Do you know how I could get the chart just to evenly fit that 14 day spread automatically and auto follow price around? Thanks again! |
[2023-03-23 05:51:19] |
Sierra_Chart Engineering - Posts: 19305 |
We do not understand the question.
[2023-03-23 12:28:53] |
Hmm... Basically I just want the chart to fit the 14 day without the ability to scroll the chart in the x and y directions. The chart would just stretch to fit the highs and lows and all 14 days automatically if that makes sense. Thanks |
[2023-03-23 15:26:43] |
There is not a way to force a particular size of the data into the viewable area, but you can adjust the bar spacing to get it where you want to have all the data displayed at once. Refer to the following for how to change the bar spacing: Working With Charts: Changing Bar Spacing For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
