Date/Time: Tue, 22 Apr 2025 22:56:44 +0000
[User Discussion] - sierra charts unuseable
View Count: 817
[2023-03-22 13:41:27]
User654138 - Posts: 27
In the last 2 weeks I have lost pretty much all functionality with sierra charts. I am running on a mac thru crossover and it worked fin for about 3 years now it keeps freezing, buttons and drop downs don't work and I can't adjust scales on charts. I was disconnecting and reconnecting and that worked for awhile, now it is having no effect. I have reinstalled mac os, I have reinstalled both sierra and crossover with no improvement. I would really prefer to stay with sierra but unless I can regain functionality I won't be able to.
[2023-03-22 14:09:26]
John - SC Support - Posts: 39428
The issues you are having are going to be related to running on a MAC, as we are not having these troubles with users on Windows. As you are aware, Sierra Chart is only built for Windows.
We have set this as a "User Discussion" as we can not help, but there are other users using a MAC that might be able to help.
[2023-03-22 14:12:11]
Sierra_Chart Engineering - Posts: 19305
Have you first tried to just start with one simple chart and see if you have any issues with that?
[2023-03-22 15:32:41]
Tony - Posts: 565
Is your Mac Intel or M1/M2? Crossover is not stable/reliable on both chips.
Date Time Of Last Edit: 2023-03-22 15:34:46
[2023-03-24 15:15:31]
it's a silicon chip, I erased the hard drive and reinstalled everything. It starts out okay but I gradually lose functionality. Data streams but order buttons don't work, I can't access settings menus. I used to be able to disconnect and reconnect and regain functionality but now that doesn't work. If I close sierra and then log in again it usually works. I never had this problem before about 2 months ago, I really like sierra and I don't want to have to switch.
[2023-03-24 15:54:02]
Tony - Posts: 565
Unfortunately there's no ideal solution for silicons, Crossover has a hard time to run natively, you could try Oracle's Virtual Box, (which is free) or Parallels, they both run natively.
Sierra has a lot of things that other platforms don't, unless you could live without them, I would get a 2nd computer just for Sierra, doesn't have to be fancy, Sierra is very efficient, uses little resources
Good luck.
Date Time Of Last Edit: 2023-03-24 16:03:10
[2023-03-24 16:29:57]
Recommend getting Intel or AMD based computer that can run Windows 7 and just use Windows 7 to run Sierra Chart.
[2023-03-24 16:29:58]
Recommend getting an Intel or AMD based computer that can run Windows 7 and just use Windows 7 to run Sierra Chart.
Date Time Of Last Edit: 2023-03-24 16:30:05
[2023-03-24 16:31:35]
I'll give those a shot, I'll let you know. I run sierra on my linux ubuntu laptop thru crossover, it seems stable
[2023-03-24 18:37:42]
virtual box kept crashing with 64, I'm setting up parallels, how much memory, processor and disk space would you recommend?
[2023-03-27 01:35:10]
I went with parallels running on windows 11, works great, thanks for your assistance
[2023-03-27 13:12:10]
seandunaway - Posts: 348
For anyone else having problems with wine on macOS this is relevant:
Sierra Chart Executables for ARM 64 Processor
Date Time Of Last Edit: 2023-03-27 13:12:49
